show ports sharing
show ports port_list sharing distribution configuration
Description
Displays port load-sharing groups, or LAGs.
Syntax Description
Default
N/A.
Usage Guidelines
Output from this command displays the following information:
Following is sample output displaying link aggregation on a switch:
show port sharing
Load Sharing Monitor
Config    Current Agg      Min    Ld Share   Ld Share  Agg  Link   Link Up
Master    Master  Control  Active Algorithm  Group     Mbr  State  Transitions
    14                      <2      L2         14       -     R       0
                                    L2         15       -     A       1
                                    L2         16       -     R       0
    17     35     Static     1      L2         17       -     R       0
                                    L2         35       Y     A       1
Link State: A-Active, D-Disabled, R-Ready, NP-Port not present, L-Loopback
Minimum Active: (<) Group is down. # active links less than configured minimum
Load Sharing Algorithm: (L2) Layer 2 address based, (L3) Layer 3 address based
                        (L3_L4) Layer 3 address and Layer 4 port based
                        (custom) User-selected address-based configuration
Custom Algorithm Configuration: ipv4 L3-and-L4, xor
Custom Hash Seed: Switch MAC address (0x969BF582)
Number of load sharing trunks: 2
The LACP feature was added in ExtremeXOS 11.3.
The Health Check LAG was added in ExtremeXOS 12.1.3.
The round-robin algorithm was added in ExtremeXOS 12.5.
Support for the Min Active parameter was added in ExtremeXOS 15.7.1.
Custom hash seed information was added in ExtremeXOS 30.1.
Platform Availability
